Asteroidockultationer hösten 2013
Nedan har jag plockat ut de asteroidockultationer under perioden september – november 2013 som jag tycker ser mest lovande ut för svenskt vidkommande:
Sep 06: http://asteroidoccultation.com/2013_09/ ... 73_Map.gif
Sep 07: http://asteroidoccultation.com/2013_09/ ... 22_Map.gif
Sep 09: http://asteroidoccultation.com/2013_09/ ... 83_Map.gif
Sep 14: http://asteroidoccultation.com/2013_09/ ... 89_Map.gif
Sep 17: http://asteroidoccultation.com/2013_09/ ... 52_Map.gif
Sep 18: http://asteroidoccultation.com/2013_09/ ... 56_Map.gif
Sep 20: http://asteroidoccultation.com/2013_09/ ... 62_Map.gif
Sep 27: http://asteroidoccultation.com/2013_09/ ... 09_Map.gif
Okt 02: http://asteroidoccultation.com/2013_10/ ... 95_Map.gif
Okt 11: http://asteroidoccultation.com/2013_10/ ... 20_Map.gif
Okt 21: http://asteroidoccultation.com/2013_10/ ... 52_Map.gif
Okt 24: http://asteroidoccultation.com/2013_10/ ... 40_Map.gif
Okt 26: http://asteroidoccultation.com/2013_10/ ... 64_Map.gif
Okt 29: http://asteroidoccultation.com/2013_10/ ... 71_Map.gif
Okt 31: http://asteroidoccultation.com/2013_10/ ... 78_Map.gif
Nov 04: http://asteroidoccultation.com/2013_11/ ... 95_Map.gif
Nov 04: http://asteroidoccultation.com/2013_11/ ... 98_Map.gif
Nov 05: http://asteroidoccultation.com/2013_11/ ... 99_Map.gif
Nov 09: http://asteroidoccultation.com/2013_11/ ... 07_Map.gif
Nov 09: http://asteroidoccultation.com/2013_11/ ... 08_Map.gif
Nov 12: http://asteroidoccultation.com/2013_11/ ... 48_Map.gif
Nov 12: http://asteroidoccultation.com/2013_11/ ... 66_Map.gif
Nov 17: http://asteroidoccultation.com/2013_11/ ... 28_Map.gif
Nov 20: http://asteroidoccultation.com/2013_11/ ... 38_Map.gif
Nov 22: http://asteroidoccultation.com/2013_11/ ... 45_Map.gif
Nov 25: http://asteroidoccultation.com/2013_11/ ... 63_Map.gif
Nov 27: http://asteroidoccultation.com/2013_11/ ... 44_Map.gif
Nov 30: http://asteroidoccultation.com/2013_11/ ... 79_Map.gif
Re: Asteroidockultationer hösten 2013
Jag har nu uppdaterat ovanstående lista med länkar till mera detaljerade zonkartor, när sådana finns tillgängliga. Dessa nya kartor innehåller "MapE" i länkadressen.
Sep 06: http://asteroidoccultation.com/2013_09/ ... 3_MapE.gif
Sep 07: http://asteroidoccultation.com/2013_09/ ... 2_MapE.gif
Sep 14: http://asteroidoccultation.com/2013_09/ ... 3_MapE.gif
Sep 17: http://asteroidoccultation.com/2013_09/ ... 2_MapE.gif
Sep 18: http://asteroidoccultation.com/2013_09/ ... 6_MapE.gif
Okt 02: http://asteroidoccultation.com/2013_10/ ... 5_MapE.gif
trank
Post by trank »
Jag behöver hjälp att förstå hur jag hittar stjärnor i olika kataloger. Ockultationen som sker 31 okt ligger hyfsat till där jag bor (Lerum). Nu är den kanske lite svag för att jag ska ha lcykas, men jag vill öva.
Men hur hittar jag 2UCAC 40306977 i mina program (jag använder Skytools och Stellarium)? Vad är UCAC för för en katalog?
jwarell
Post by jwarell »
Hej Magnus,
Databaserna vid CDS är lösningen om du har en katalogbeteckning men saknar koordinater. Om du går till VizieR
http://vizier.u-strasbg.fr/viz-bin/VizieR
kan du knacka in UCAC2 som katalog (Find cataolgue, överst), sedan ange stjärnans ID i katalogens designation-ruta. Då får du info bla koordinater. Du kan också läsa om katalogens uppbyggnad och innehåll.
I detta fall var ju koordinaterna redan kända från ockultationsberäkningen. I planetarieprogrammet kan du helt enkelt gå till den positionen om programmet inte hämtar UCAC2-info via nätet. Då ser du din stjärna där om GSC-katalogen finns inbyggd, det gör den nästan alltid nuförtiden.
I Vizier kan du också söka information om ett objekts förekomst i samtliga tillgängliga kataloger om du känner till tex dess koordinater. Ange 05 00 37.342 +24 17 36.44 i andra rutan på Viziersidan, ändra till 0,1 bågmin sökradie, och du får en lång lista med träffar i olika kataloger där objekt nära koordinaten finns.
Bla ser du då att UCAC2-stjärnan även heter USNO-A2 1125-01975559, GSC 0183200247 etc. Någon av dessa kataloger finns säkert i planetarieprogrammet och kan identifieras genom detta alternativa ID.
Alternativt går du till AAVSO Variable Star Plotter, anger positionen och trycker plot chart. Då får du en karta med stjärnan centrerad.
http://www.aavso.org/vsp
Testa! Mvh Johan
Nu har vi en mera detaljerad zonkarta för Eleutheria-ockultationen natten 30-31 oktober 2013. I vårt land inträffar ockultationen klockan 00:42 eller 00:43 UT (dvs 01:42 eller 01:43 svensk normaltid). Den exakta tiden beror på om man bor på Gotland (tidigare klockslag) eller i Göteborgsområdet (senare klockslag).
http://asteroidoccultation.com/2013_10/ ... 8_MapE.gif
För att få fram bra kartor tycker jag att AAVSO:s kartmaskin (som Johan W länkar till ovan) är helt suverän. Man kan då få kartorna exakt som man vill ha dem. Även om man önskar spegelvända kartor så går det bra, man klickar i väderstrecken enligt eget behov. För egen del använder jag Newton, och då blir det ju ingen spegelvändning, utan söder uppåt och väster åt vänster.
Enklast i sådana här fall (när det inte rör sig om katalogiserade variabler) tycker jag är att strunta i stjärnans olika katalognamn och helt gå på koordinaterna.
Nedan finns en karta 0.5x0.5 grader. Den har söder uppåt och väster åt vänster, som i ett Newton-teleskop. Sedan behöver man förstås även översiktskartor, men sådana ser jag som en bra övningsuppgift att framställa.
Ett bra tips när det gäller asteroidockultationer:
Kolla gärna in området i förväg (exempelvis första bästa klara natt), så att fältstjärnorna redan är välkända i god tid innan ockultationen äger rum.
Eleutheria-ockultationen.
trank
Post by trank »
Tack för hjälpen.
Jag förstår, ska ta för vana utgå från koordinaterna och inte namnet på stjärnan.
Nu väntar jag på klart väder föra att öva att hitta stjärnan och närområdet.
/Magnus
trank
Post by trank »
Igår var jag ute o övade, dvs letade upp stjärnan 2UCAC 40306977 som ska ockuleras den sista oktober.
Jag såg den inte visuellt genom teleskopet, men tror att jag lyckades fånga den med min kamera.
Förvisso var det halvmåne ute igårkväll, men jag gissar att det blir svårt att kunna visuellt se denna ockultation med mitt teleskop (En Skywatcher Explorer-200P) med tanke på magnituden på stjärnan.
Så då undrar jag om det är möjligt att fånga den med driftskanning?
Har läst på http://www.saaf.se/driftskanning.php om driftskanning ochhar några frågor.
Vad betyder Binningsfaktor?
Jag tog en 45 sekunders bild och stängde av följningen efter 15 sekunder och fick följande bild. (obs bilderna är klippta).
Jag kan knappt urskilja stjärnan på denna bild. Är den för svag för driftskanning?
Jag använde iso800, det kanske borde skruvas upp?
Några andra tips? Det borde väl räcka med att foto i primärfokus?
Med min begränsade erfarenhet kanske denna ockultation är i svåraste laget, men jag kan inte sluta att drömma om att lyckas dokumentera en astroidockultation.
Tack på förhand.
/Magnus
Det känns som om du förbereder dig på precis rätt sätt!
Jag har inga kommentarer till bilderna, men när det gäller den visuella synbarheten av stjärnan med magnitud 12.5 så borde den vara tillräckligt stark för att ses i ditt teleskop. Jag har ett nästan identiskt instrument (Celestron 20 cm f/5), och från min balkong i Göteborg ser jag under hyggliga atmosfäriska förhållanden magnitud 12.5 redan med direkt seende. Och just direkt seende är nästan nödvändigt för att man med säkerhet ska upptäcka när stjärnan "slocknar".
Möjligen har du använt för låg förstoring? Okular med brännvidd 4-7 mm är bäst när man ska titta på svaga stjärnor med ditt teleskop. Vid låg eller medelhög förstoring ser man bara de starkaste stjärnorna.
m v h
