Helt gratis och har en rad smidiga funktioner för bildprocessering.
Perform dark frame subtraction on raw files
To reduce noise in long exposures, some cameras can be set to automatically record a second exposure (called a "dark frame") with the shutter closed and subtract it from the previous exposure. This method works well, but consumes time and battery power. Using Pixel Fixer's Dark Frame Subtraction tool this process can be now performed in software instead, using a lens-cap shot as the dark frame.
This feature is still in development, and currently only works on NEF & CR2 files. To add support for Pentax/Leica cameras, I need sample long exposures accompanied by suitable dark frames. If you'd like to contribute samples, just e-mail them to this address.
Extract embedded JPEGs
Many cameras produce raw files that have JPEG images embedded in them. Pixel Fixer can extract these images and save them as seperate files with EXIF information included, so that you can get a quick preview of what your raw files contain without having to shoot "Raw + JPEG" or process all the files with a raw converter.
Rename raw files
Pixel Fixer can rename your raw files (and the corresponding JPEG) while it's working, making it a useful part of your workflow.
Show number of shutter releases
Some DSLR cameras record the total number of shutter releases in each file. Pixel Fixer can extract this number from raw files.
Associate with folders and files
You can tell Pixel Fixer to associate itself with folders and raw files, for easy right-click access.
Multi-threaded processing
Pixel Fixer can use mutliple threads to improve performance on multi-core/multi-processor systems.
Supported cameras:
Nikon
D1, D1H, D1X
D2H/D2Hs
D2X/D2Xs
D3/D3S, D3X
D700, D800/D800E
D4
D100, D200
D70/D70s
D50, D60, D80, D90
D40/D40X
D300/D300s
D5000, D5100
D3000, D3100, D3200
D7000
Coolpix 5000
Coolpix 5700
Coolpix 5400
Coolpix 8700
Coolpix 8400
Coolpix 8800
Nikon 1 V1
Nikon 1 J1
Canon
EOS 1D
EOS 1Ds
EOS 1D Mark II
EOS 1Ds Mark II
EOS 1D Mark II N
EOS 1D Mark III
EOS 1Ds Mark III
EOS 1D Mark IV
EOS 7D
EOS 5D
EOS 5D Mark II
EOS 5D Mark III
EOS 20D
EOS 30D
EOS 40D
EOS 50D
EOS 60D
PowerShot G9/G10/G11/G12
PowerShot G1X
PowerShot S90/S95/S100
EOS 350D/Digital Rebel XT
EOS 400D/Digital Rebel XTi
EOS 450D/Digital Rebel XSi
EOS 500D/Digital Rebel T1i
EOS 550D/Digital Rebel T2i
EOS 600D/Digital Rebel T3i
EOS 650D/Digital Rebel T4i
EOS 1000D/Digital Rebel XS
EOS 1100D/Digital Rebel T3
Pentax
K10D
K20D
*ist D
*ist DS/DS2
*ist DL/DL2
K100D
K110D
K100D Super
K200D
Leica
M8 Digital Camera
M8.2 Digital Camera
M9 Digital Camera
Mvh Marko
