DSS i ny version, nu 4.2.2 beta 2
Juicy6
Inläggav Juicy6 » 2019-08-13 09:34:33
https://github.com/deepskystacker/DSS/releases/tag/4.2.2-Beta2
This release is all about performance, though other areas have been enhanced as well. The main changes since 4.2.1 are:
1. Changes to star registration code to detect larger stars than before. Star radius of up to 50 pixels is now valid (it was 20 pixels). This was needed to accomodate higher resolution sensors.
2. Allow larger star sizes to the specified in the Star Mask creation dialogue. Star diameter of up to 100 pixels is now allowed. This was needed to accomodate higher resolution sensors.
3. OpenMP speedup of Star Mask image reading code.
4. Huge speedup of final image display by using much larger rectangles and OpenMP speedup of the bitmap extraction code.
5. Speed up star registration by updating progress indicator once every 25 iterations instead of each iteration.
6. Computing Final Picture using Kappa-Sigma Clip processing is now about 50 times faster!
7. Computing Final Picture using Auto Adaptive Weighted Average is now about 43 times faster!
8. Auto-Adaptive Weighted Average now re-written completely. It should no longer produce whited out images or other strange results. Thanks to Michael A. Covington and Simon C. Smith for their immense help in locating references and getting this working.
9. Update LibRaw to 0.19.3.
10. Reverted Entropy calculation code in CEntropyInfo::InitSquareEntropies() to NOT compute in parallel - some called code wasn't thread safe.
11. Entropy Weighted Average complete stack of 50 lights is now about 20 times faster on my laptop, down from 4hrs 22min to 12min 55 sec.
12. Bug fix - changing "Set the black point to 0" or "Use Camera White Balance" after an image was loaded didn't change the rendering.
13. When loading raw files, check that the camera is listed in the LibRaw supported camera list. Issue a warning if not.
14. User request to change the file open dialog to default to *all* supported image types including raw files.
15. Three times performance improvement in star registration.
Christer, Uddevalla
TS Optics 80/480/f6 APO
Canon 200D moddad för widefield
ZWO ASI385 för "narrowfield"
AZ-EQ5GT och Polemaster
Återgå till "Programvara"
Användare som besöker denna kategori: 21 och 0 gäster
