Telegizmos 365 T3G1 Teleskopskydd för 8" -10" SCT Teleskop
skyhaze
Post by skyhaze »
Telegizmos 365 T3G1 Teleskopskydd för 8" -10" SCT Teleskop på EQ montering
Skyddet är avsett för permanent bruk utomhus. Jag har haft skyddet utomhus på teleskoppier under några år i is snö vind och regn utan problem. Håller bra bruksskick.
Pris 1000kr inkl frakt inom Sverige
Erik Berglund 0702644840 / sm3wsv@gmail.com
Nedanstående spec har jag saxat från Telegizmos hemsida.
This TeleGizmos 365 Series Cover is made to fit equatorially mounted 8", 9.25", and 10" SCTs.
The 365 is a multi layered/dual material design with an inner radiant barrier coupled to an outer cover made of high count, acrylic coated woven polyester.
The inner liner radiant barrier provides radiant heat protection and additional protection from water penetration.
The outer covers acrylic coated weave provides resistance to mildew and UV as well as amazing water resistant capabilities. Allowed no moisture penetration from a spray test conducted at 40 PSI, 1/2" concentrated stream.
The TeleGizmos 365 Cover is capable of handling all types of weather on a continuous 24 hour a day, 365 day a year basis.
skyhaze
Re: Telegizmos 365 T3G1 Teleskopskydd för 8" -10" SCT Teleskop
Post by skyhaze »
Sänker priset till 800kr inkl frakt
skyhaze
Post by skyhaze »
Sänker priset till 600kr
Return to “Säljes”
