Aktuella kometer
Re: Aktuella kometer
Inläggav Hans Bengtsson » 2017-02-15 11:25:06
Aktuella kometer, enligt de kriterier som anges i trådens första inlägg.
18 februari 2017, 00 UT:
Mag 8: 45P/Honda-Mrkos-Pajdusakova, pos 1305+32, elong 133
Mag 9: 2P/Encke, pos 0002+07, elong 34
Mag 10: C/2015 V2 (Johnson), pos 1602+45, elong 98
Mag 10: C/2015 ER61 (PanSTARRS), pos 1722-23, elong 67
Mag 11: 41P/Tuttle-Giacobini-Kresak, pos 0935+19, elong 169
Mag 12: 73P/Schwassmann-Wachmann 3, pos 1845-20, elong 48
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2049-18, elong 19
Mag 14: 315P/2013 V6 (LONEOS), pos 1203+30, elong 146
Mag 14: 103P/Hartley 2, pos 2221-03, elong 9
Inläggav Hans Bengtsson » 2017-02-20 09:42:03
25 februari 2017, 00 UT:
Mag 8: 2P/Encke, pos 0008+07, elong 28
Mag 9: C/2015 V2 (Johnson), pos 1612+45, elong 100
Mag 10: 45P/Honda-Mrkos-Pajdusakova, pos 1137+28, elong 155
Mag 10: C/2015 ER61 (PanSTARRS), pos 1749-23, elong 68
Mag 10: 41P/Tuttle-Giacobini-Kresak, pos 0940+24, elong 160
Mag 12: 73P/Schwassmann-Wachmann 3, pos 1922-21, elong 47
Mag 13: C/2016 U1 (NEOWISE), pos 2323-30, elong 24
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2055-18, elong 25
Mag 14: 315P/2013 V6 (LONEOS), pos 1200+31, elong 149
Mag 14: 103P/Hartley 2, pos 2243-01, elong 8
Inläggav Hans Bengtsson » 2017-03-02 11:11:38
4 mars 2017, 00 UT:
Mag 7: 2P/Encke, pos 0003+03, elong 19
Mag 9: C/2015 V2 (Johnson), pos 1619+46, elong 101
Mag 9: C/2015 ER61 (PanSTARRS), pos 1817-23, elong 69
Mag 9: 41P/Tuttle-Giacobini-Kresak, pos 0948+31, elong 150
Mag 11: 45P/Honda-Mrkos-Pajdusakova, pos 1102+25, elong 160
Mag 12: 73P/Schwassmann-Wachmann 3, pos 1959-20, elong 45
Mag 13: C/2016 VZ18 (PanSTARRS), pos 0230+33, elong 64
Mag 13: 103P/Hartley 2, pos 2307+00, elong 7
Mag 14: C/2016 U1 (NEOWISE), pos 2349-28, elong 25
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2100-17, elong 30
Mag 14: 315P/2013 V6 (LONEOS), pos 1155+32, elong 151
Mag 14: 71P/Clark, pos 1542-12, elong 107
Inläggav Hans Bengtsson » 2017-03-06 09:58:55
11 mars 2017, 00 UT:
Mag 6: 2P/Encke, pos 2332-04, elong 2
Mag 8: 41P/Tuttle-Giacobini-Kresak, pos 1005+39, elong 139
Mag 9: C/2015 V2 (Johnson), pos 1626+46, elong 102
Mag 9: C/2015 ER61 (PanSTARRS), pos 1848-22, elong 69
Mag 12: 45P/Honda-Mrkos-Pajdusakova, pos 1046+23, elong 158
Mag 12: 73P/Schwassmann-Wachmann 3, pos 2036-20, elong 44
Mag 13: C/2016 VZ18 (PanSTARRS), pos 0244+42, elong 64
Mag 13: C/2017 E1 (Borisov), pos 1959-09, elong 51
Mag 13: 103P/Hartley 2, pos 2332+02, elong 6
Mag 14: C/2016 U1 (NEOWISE), pos 0012-27, elong 25
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2105-17, elong 36
Mag 14: 315P/2013 V6 (LONEOS), pos 1150+32, elong 150
Mag 14: 71P/Clark, pos 1552-13, elong 111
Inläggav Hans Bengtsson » 2017-03-13 11:41:49
18 mars 2017, 00 UT:
Mag 7: 2P/Encke, pos 2254-12, elong 18
Mag 7: 41P/Tuttle-Giacobini-Kresak, pos 1036+49, elong 129
Mag 9: C/2015 V2 (Johnson), pos 1630+47, elong 104
Mag 9: C/2015 ER61 (PanSTARRS), pos 1920-20, elong 68
Mag 11: TJL006, pos 1939-22, elong 64
Mag 12: 73P/Schwassmann-Wachmann 3, pos 2111-19, elong 42
Mag 13: 45P/Honda-Mrkos-Pajdusakova, pos 1037+21, elong 152
Mag 13: C/2016 VZ18 (PanSTARRS), pos 0304+52, elong 66
Mag 13: C/2017 E1 (Borisov), pos 2038-08, elong 48
Mag 13: 103P/Hartley 2, pos 2358+04, elong 5
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2110-16, elong 42
Mag 14: 315P/2013 V6 (LONEOS), pos 1145+32, elong 148
Mag 14: 71P/Clark, pos 1602-13, elong 115
Inläggav timokarhula » 2017-03-18 00:28:46
Obsade två kometer ikväll med prismakikare. C/2015V2 (Johnson) såg jag med 25x100 i Herkules. Skattade kometen till magnitud 9.7, diameter 2'.5 och DC=4/. 41P/Tuttle-Giacobini-Kresak var en trevlig överraskning. Hittade den först med 25x100 och den var stor, ljus men ganska diffus. 41P syntes även rätt så enkelt med 10x50 kikare på fri hand. Skattade komet T-G-K som magnitud 7.5, diameter 10' och DC=3. Det trevliga är att båda kometerna närmar sig jorden och ljusnar ytterligare. Kanske kan 41P/Tuttle-Giacobini-Kresak ses med blotta ögat om en vecka eller så.
Inläggav AstroFriend » 2017-03-18 07:54:58
Rolf och jag hade planer för kometfoto på fredagen här i Stockholms omnejd, men tyvärr fick molnen oss att ställa in det. Kallt och ganska blåsigt dessutom. Det är 41P vi siktar på i första hand.
Jag tänkte köra Sigma APO 150mm f/2.8 på fullframe och Rolf med mindre teleskop.
Inläggav Hans Bengtsson » 2017-03-22 08:49:38
25 mars 2017, 00 UT:
Mag 6: 41P/Tuttle-Giacobini-Kresak, pos 1138+58, elong 119
Mag 8: 2P/Encke, pos 2236-16, elong 30
Mag 8: C/2015 ER61 (PanSTARRS), pos 1954-19, elong 67
Mag 9: C/2015 V2 (Johnson), pos 1632+47, elong 105
Mag 11: C/2017 E4 (Lovejoy), pos 2032-08, elong 56
Mag 12: 73P/Schwassmann-Wachmann 3, pos 2144-17, elong 41
Mag 12: 103P/Hartley 2, pos 0025+06, elong 5
Mag 13: C/2017 E1 (Borisov), pos 2117-07, elong 45
Mag 13: 71P/Clark, pos 1611-14, elong 120
Mag 14: 45P/Honda-Mrkos-Pajdusakova, pos 1033+20, elong 146
Mag 14: C/2016 VZ18 (PanSTARRS), pos 0335+61, elong 70
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2115-16, elong 48
Inläggav Hans Bengtsson » 2017-04-04 11:39:43
8 april 2017, 00 UT:
Mag 5: 41P/Tuttle-Giacobini-Kresak, pos 1531+63, elong 104
Mag 7: C/2017 E4 (Lovejoy), pos 2252+26, elong 37
Mag 8: C/2015 ER61 (PanSTARRS), pos 2104-13, elong 63
Mag 8: C/2015 V2 (Johnson), pos 1627+47, elong 109
Mag 11: C/2017 E1 (Borisov), pos 2232-03, elong 40
Mag 11: 2P/Encke, pos 2234-18, elong 45
Mag 12: 103P/Hartley 2, pos 0121+10, elong 4
Mag 13: 73P/Schwassmann-Wachmann 3, pos 2244-13, elong 41
Mag 13: 71P/Clark, pos 1626-16, elong 130
Mag 14: C/2016 R2 (PanSTARRS), pos 0318-18, elong 41
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2123-15, elong 59
Inläggav timokarhula » 2017-04-06 09:22:25
Jag observerade två kometer av magnitud 6.5 imorse klockan 3:40 med 7x50-kikare. Trots samma totalmagnitud såg de helt olika ut. Den ena var 41P/Tuttle-Giacobini-Kresak, komadiameter hela 30' (som fullmånen) och låg i zenit i Draken. 41P var mycket diffus (DC=2). Den andra kometen var nykomlingen C/2017E4 (Lovejoy) i Pegasus. Lovejoy var stjärnlik (DC=7) och liten, 4'. Gränsmagnituden i zenit var så bra som 6.2 trots den 74% upplysande månen. Båda kometerna kunde jag även se med minimala 8x20-kikare. C/2017E4 är min fjärde Lovejoy-komet. Jag och Terry Lovejoy är lika gamla och vi träffades under den totala solfömörkelsen den 4 december 2002 i South Australia Outback. Kul att se ännu en av hans kometer. Han fortsätter upptäcka fina kometer hemifrån trots proffsens helautomatiska kometsökarprojekt.
jwarell
Inläggav jwarell » 2017-04-08 10:52:48
timokarhula skrev:Jag observerade två kometer av magnitud 6.5 imorse klockan 3:40 med 7x50-kikare. Trots samma totalmagnitud såg de helt olika ut. Den ena var 41P/Tuttle-Giacobini-Kresak, komadiameter hela 30' (som fullmånen) och låg i zenit i Draken. 41P var mycket diffus (DC=2). Den andra kometen var nykomlingen C/2017E4 (Lovejoy) i Pegasus. Lovejoy var stjärnlik (DC=7) och liten, 4'. Gränsmagnituden i zenit var så bra som 6.2 trots den 74% upplysande månen. Båda kometerna kunde jag även se med minimala 8x20-kikare. C/2017E4 är min fjärde Lovejoy-komet. Jag och Terry Lovejoy är lika gamla och vi träffades under den totala solfömörkelsen den 4 december 2002 i South Australia Outback. Kul att se ännu en av hans kometer. Han fortsätter upptäcka fina kometer hemifrån trots proffsens helautomatiska kometsökarprojekt.
Jag var ute samma morgon som du Timo och observerade dessa kometer, med mycket snarlikt resultat. Obsade dessutom C/2015 V2. Har kommenterat obsarna i denna råd med diagram från COBS:
http://astronet.se/phpBB3/viewtopic.php?f=59&t=14537&p=67336#p67336
/Johan
T38 | T25 | T25 | T22 | B10
Inläggav timokarhula » 2017-04-08 13:29:40
Kul att vi prickade in en och samma klara morgon innan fullmånen. Månen var ju uppe redan nu men var ganska lågt och störde inte så värst mycket. Jag hade satt klockan på ringning klockan 3 två tidigare morgnar men dimmoln hade täckt himlen trots en hygglig chans för klart väder enligt prognoserna dagen innan. Komet C/2017E4 (Lovejoy) var mitt främsta mål och den såg ut som en suddig stjärna med 7x50. En välkoncentrerad komet, likt 2P/Encke vid liten solelongation. Lovejoy kommer att bli ett fint objekt nära Andromedagalaxen efter påsk. 41P/Tuttle-Giacobini-Kresak var en stor blaffa i zenit, inte olik M33 eller en större variant av M101. C/2015V2 (Johnson) hade jag inte plottat ut på kartan men jag hade märkt att kometen hade haft en mycket liten rörelse på himlen de senaste veckorna så den hade nog också hittats med 7x50 utan karta. Obsade Johnson med 10x50 den 21 mars utan större svårighet. C/2015ER61 (PanSTARRS) har fått ett utbrott och kan vara den ljusaste kometen på himlen just nu. Den kommer att bli svår (omöjlig?) att se från Svealand och norröver då den aldrig är högt uppe vid gryningen.
Johan, ser att du använder dig av referensen GB (Guide Star Photometric Catalog - II). Finns den inkorporerad i någon av dina mjukvaror (planetarieprogram) som du använder?
jwarell
Inläggav jwarell » 2017-04-09 12:50:53
timokarhula skrev: C/2015ER61 (PanSTARRS) har fått ett utbrott och kan vara den ljusaste kometen på himlen just nu. Den kommer att bli svår (omöjlig?) att se från Svealand och norröver då den aldrig är högt uppe vid gryningen.
C/2015 ER61 är mycket intressant. Den verkar redan ha toppat på mag 6,0, och finns tecken på att den börja tappa i ljusstyrka efter utbrottet. DC-skattningarna ligger på 5-7 så den borde kunna gå att fånga på låg höjd.
Jag använder Sky Safari Pro 3.8.5 i fält som verkar har GSC2 som magnitudkälla, det nämns inte specifikt men jag har kollat mot Vizier och det stämmer bra.
/Johan
Inläggav Hans Bengtsson » 2017-05-02 11:51:37
29 april 2017, 00 UT:
Mag 6: 41P/Tuttle-Giacobini-Kresak, pos 1807+41, elong 104
Mag 7: C/2015 ER61 (PanSTARRS), pos 2246-02, elong 56
Mag 8: C/2015 V2 (Johnson), pos 1557+44, elong 117
Mag 11: C/2017 E1 (Borisov), pos 0009+00, elong 36
Mag 11: 103P/Hartley 2, pos 0250+14, elong 6
Mag 12: 71P/Clark, pos 1640-19, elong 147
Mag 13: 73P/Schwassmann-Wachmann 3, pos 2359-07, elong 42
Mag 13: 2P/Encke, pos 2247-17, elong 62
Mag 13: C/2017 E4 (Lovejoy), pos 0150+35, elong 22
Mag 14: 65P/Gunn, pos 1626-20, elong 150
Mag 14: C/2016 R2 (PanSTARRS), pos 0335-14, elong 33
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2134-14, elong 7
Inläggav Hans Bengtsson » 2017-05-08 15:48:39
13 maj 2017, 00 UT:
Mag 7: C/2015 ER61 (PanSTARRS), pos 2347+04, elong 53
Mag 7: C/2015 V2 (Johnson), pos 1526+38, elong 123
Mag 8: 41P/Tuttle-Giacobini-Kresak, pos 1828+28, elong 114
Mag 11: 103P/Hartley 2, pos 0351+16, elong 7
Mag 11: 71P/Clark, pos 1642-22, elong 160
Mag 12: C/2017 E1 (Borisov), pos 0103+03, elong 36
Mag 14: C/2015 VL62 (Lemmon-Yeung-PanSTARRS), pos 0022+15, elong 42
Mag 14: C/2015 O1 (PanSTARRS), pos 1845+14, elong 119
Mag 14: 217P/LINEAR, pos 2343-04, elong 57
Mag 14: 73P/Schwassmann-Wachmann 3, pos 0040-04, elong 45
Mag 14: 65P/Gunn, pos 1617-21, elong 165
Mag 14: C/2016 R2 (PanSTARRS), pos 0347-12, elong 31
Mag 14: 29P/Schwassmann-Wachmann 1, pos 2138-14, elong 89
