Supernova i M95
Robin Andersson
Re: Supernova i M95
Inläggav Robin Andersson » 2012-03-19 19:29:41
Okej tack! :)
hansg
Re: Supernova i M95
Inläggav hansg » 2012-03-19 20:20:56
Läste precis att Supernovan i stället kan vara en CV, enl Mario Motta, inlägg i Staranalyser gruppen,
ett spektra taget tyder på en CV
h-g
Re: Supernova i M95
Inläggav Lazze » 2012-03-19 20:37:40
Hej H-G
Vad innebär CV?
wilt
Re: Supernova i M95
Inläggav wilt » 2012-03-19 20:40:38
Kataklysmisk variabel; det skulle alltså kunna röra sig om en dvärgnova som U Gem eller något liknande.
hansg
Re: Supernova i M95
Inläggav hansg » 2012-03-19 20:41:32
Cataclysmic variabel:
http://imagine.gsfc.nasa.gov/docs/scien ... ables.html
finns en känd x-ray källa inom 3 arc sec från objektet, kanske samma objekt
M95 är en intressant galax
2006ApJ...647.1030S - Astrophys. J., 647, 1030-1039 (2006) - 23.08.06 12.01.07 August(III) 2006
Chandra observations of circumnuclear star formation in NGC 3351.
SWARTZ D.A.; YUKITA M.; TENNANT A.F.; SORIA R.; GHOSH K.K.
Abstract (from CDS): The nearby SB(r)b galaxy NGC 3351 (M95) displays an ~600 pc diameter star-forming circumnuclear ring fueled by gas accreted through a stellar bar. The X-ray emission from this region is composed of numerous pointlike sources embedded in hot (kT=0.5±0.1 keV), nonuniform diffuse gas. Most of the pointlike sources are likely themselves concentrated regions of hot gas. The morphology of the X-ray emission is similar to, but not identical with, UV and Hα hot spots in the circumnuclear ring. The emission morphology can be understood if star formation is occurring through a series of instantaneous starbursts at various locations around the ring and the UV, Hα, and X-ray emission trace successively later stages in the evolution of the underlying stellar populations. X-ray emission extends at least 500 pc beyond the circumnuclear ring. This emission is interpreted as the result of gas outflow from the star-forming ring into the disk and halo of NGC 3351. There is evidence that the outflow is confined by cold ambient gas near the plane of the galaxy but that flow out of the plane is not restricted. The nucleus of the galaxy lacks both large amounts of hot gas and any pointlike source above an estimated X-ray luminosity of 1037 ergs/s in the 0.5-8.0 keV band. This luminosity is orders of magnitude too low to account for the observed nuclear Hα luminosity, 3.5x1038 ergs/s, by X-ray photoionization.
Abstract Copyright: American Astronomical Society 2006
Journal keyword(s): Galaxies: Individual: NGC Number: NGC 3351 - Galaxies: Starburst - Galaxies: Structure - X-Rays: Galaxies
Nomenclature Note: Table 1: [SYT2006] aNN (Nos s1-s24, k25-k27, s28-s29, k30-k31, s32, k33-k34, s35-s53).
Simbad objects (55)
h-g
Re: Supernova i M95
Inläggav Lazze » 2012-03-19 21:18:17
Tack för infon Gustav och H-G. Bra länk också H-G.
Jag håller just på att fota M95 genom lillrefraktorn från balkongen, men tyvärr är brännvidden för kort och jag får kraftiga reflexioner i ett filter från Mars intill, så det ser ut att bli pannkaka av det försöket. Ska se om jag får något bättre tillfälle.
Re: Supernova i M95
Inläggav Bengt » 2012-03-19 21:38:56
Även jag hade problem ikväll med få bra bilder . Mars strålar som en fyr över halva bilden.
Novan går dock inte att missa.
hansg
Re: Supernova i M95
Inläggav hansg » 2012-03-20 06:32:48
Då var det klart det är en SN IIp.
Eftersom det är en platå SN kan vi vänta oss en lång tid av observationer liknande denna:
http://www.fredda-o-ac.se/KPO/snartikel.htm
Man pratar också om Platå supernovor med "svans", den från 2004 var en sådan ,då är inte nedgången efter platån så kraftig utan kurvan får en svag lutning ned till avklingande, har något med metall innehållet att göra, halveringstiden för cobolt nedgången är 111.26 d. så den radioaktiva nedgånge i SN skapar en inbromsning i ljuskurvan som visar sig som en svans och sänkningen i ljusstyrka blir noga räknat 0.00976 mag/d.
Eller för att förklara mig ,ljusstyrkan avtar med 0.00976mag/d vilket motsvarar sönderfallshastigheten för 56_Co, 56_Co omvandlas till 56_Fe, 56_Co ”härstammar” i sin tur från sönderfall av 56_Ni som bildades vid SN:s skapelse.
h-g
Re: Supernova i M95
Inläggav Hans Bengtsson » 2012-03-20 07:23:26
Standardsidan "Latest Supernovae" ändrade för ett tag sedan adress, den nya är:
http://www.rochesterastronomy.org/supernova.html
För den nu aktuella supernovan i M95 ges där en länk till den Astronet-tråd där jag just nu skriver!
Thomas:
Jag ser att den externa länken i SVO pekar på den gamla, icke fungerande adressen. Kan du ändra?
Edit:
Supernovan, som ännu saknar officiell SN-beteckning, är nu (20 mars) av visuell magnitud ca 13.1 och synlig även i ganska små amatörteleskop.
ThomasK
Re: Supernova i M95
Inläggav ThomasK » 2012-03-20 14:19:05
Supernovan har nu fått beteckningen 2012aw ser jag. Eftersom det säkert kommer in observationer av den till SVO har jag lagt in namnet så det går att börja registrera obsar.
Jag har också ändrat länken på SVO till David Bishops sida "Latest Supernovae" som var flyttad.
Re: Supernova i M95
Inläggav Bengt » 2012-03-20 17:57:52
Min 5 min rgb bild från igår.Den är svår att missa.
Re: Supernova i M95
Inläggav Hans Bengtsson » 2012-03-20 18:55:47
AAVSO har nu en magnitudsekvens för supernovan. Man skriver in SN 2012aw (med mellanslag efter SN) i AAVSO:s kartmaskin (Variable Star Plotter) och får en bra karta som man kan skriva ut.
Re: Supernova i M95
Inläggav Hans Bengtsson » 2012-03-21 07:32:18
Roligt att det nu finns en bild av SN2012aw på Astronet!
Det har skapats en särskild hemsida för stjärnan:
http://www.rochesterastronomy.org/sn2012/sn2012aw.html
Observationerna tyder på att supernovan för tillfället ljusnar i ganska makligt tempo. Visuellt ungefär:
Natten 18-19 mars: 13.7
Natten 19-20 mars: 13.5
Natten 20-21 mars: 13.3
Tänk på att stjärnans namn i SVO-sammanhang är SN2012aw (utan mellanslag) och i AAVSO-sammanhang SN 2012aw (med mellanslag). Viktigt att veta när man ska rapportera observationer.
Robin Andersson
Re: Supernova i M95
Inläggav Robin Andersson » 2012-03-21 07:49:17
Jag hoppas den orkar klättra några (ca) 1,5 magnitud till innan den börjar plana ut. Då har jag chans att se min andra supernova.
Ni som är lite mer erfarna, hur länge till tror ni den fortsätter ljusna eller är det för tidigt att avgöra?
Robin Andersson
Re: Supernova i M95
Inläggav Hans Bengtsson » 2012-03-21 08:31:44
En rimlig gissning kan vara att stjärnan forstätter att ljusna under ett par tre veckor, någon gång i april kan den nog visuellt nå magnitud 12.5 eller kanske 12.0. Eftersom detta spektralt rapporteras vara en platåsupernova så kan vi sedan förvänta oss att den under lång tid kan hålla sig kvar på relativt ljusstark nivå.
Men detaljerna kan vi inte veta i förväg, varje enskild supernova har sina individuella egenheter.
Edit:
Det är intressant att se, hur tydligt det framgår av Bengts bild att M95 är en stavspiral! Det vore förresten jätteroligt om bilden kunde skickas in till "Latest Supernovae" så får den en mycket större spridning och kan användas när supernovan så småningom ska sammanfattas. Det är förstås viktigt att du då anger instrument och inte minst datum och klockslag UT för bilden. I mina ögon är detta den mest intressanta bilden jag sett på Astronet hittills i år.
